need a cluster shaft for a t56
Old 08-31-2009, 05:38 PM
jesse06's Avatar
Default need a cluster shaft for a t56
i have a 06 gto and had somehow ripped the teeth off of the 1st-4th gear cluster shaft where it pushes into 5th 6th and reverse i would like to find another t56 or just parts let me know if anybody can help thanks.
Old 08-31-2009, 08:20 PM
SStolen's Avatar
Take a good look at your gears too. I had to replace 1st thru 4th, the cluster and my input shaft. Everything was f@cked one way or another,
Old 09-01-2009, 07:54 AM
thesource's Avatar
So you ripped the lugs off the back of the cluster gear?
Old 09-01-2009, 08:50 AM
the_merv's Avatar
How the hell do you do that..lol
Old 09-01-2009, 11:22 AM
jesse06's Avatar
yeah it kicks out of first the synchro and that gear is messed up pretty bad also. its sad that ive only had the car for 4 months. and it only has 62k miles. Are the t56's just a bad tranny?
but i have no idea how it broke the teeth off of the cluster shaft i dont know what would cause that. Does it happen often with t56's?
Old 09-01-2009, 07:12 PM
passnu2's Avatar
I'm glad I'm not the only one looking for a cluster shaft. Mine lost sixth and was trying to push out of fifth. It also chewed up the teeth on the cluster shaft extension. So far D&D is the only one I've looked at that sell the cluster shaft. It's just alittle pricey at $599.
Old 09-01-2009, 08:39 PM
thesource's Avatar
They are very pricey new.
Old 09-02-2009, 06:35 PM
passnu2's Avatar
I don't know if you can buy the shaft without the gears or not? If you can it should save quite a bit of money. If anyone knows the answer to this please post up and help us out.
Old 09-02-2009, 08:34 PM
jesse06's Avatar
i thought it was all one piece with barrings pressed on both ends
Old 09-03-2009, 05:52 PM
passnu2's Avatar
It might be. I haven't looked that close at mine since my mechanic tore it apart.
Old 09-03-2009, 06:10 PM
LS123's Avatar
First, GTO T56 uses the same internal parts as Vettes(F body T56 are completely different). I do have extra cluster gears if you want to buy one. This came out of a 950+ RWHP Vette and it did not survived.
Old 09-03-2009, 06:11 PM
LS123's Avatar
Sent PM.
Old 09-05-2009, 05:33 PM
passnu2's Avatar
Pm replied. Wish I had a vette!!!
Quick Reply: need a cluster shaft for a t56
