Blocking heater nipples
Old 09-01-2009, 06:05 PM
67Firebird455's Avatar
Default Blocking heater nipples
Are you guys using pipe plugs or something on these things? I'm doing a conversion into a 67 bird and don't have a heater core, and don't want one, I need these things sealed up. Would rather not weld them shut in case I use the pump as a core for a new one. Advice? Thanks fellas.
Tony
Old 09-01-2009, 10:01 PM
massls1guy's Avatar
Don't block them, it will cause problems. You need to put a short hose on there to connect them, basically a heater bypass.
Old 09-02-2009, 12:17 AM
So just straight hose nipple to nipple eh? Hmmmm...
Old 09-02-2009, 12:27 AM
nemss1's Avatar
How does it cause probs and what probs does it cause to block em?
Old 09-02-2009, 08:32 AM
H8TO WRK's Avatar
ya it is common to block them what issues are caused?
Old 09-02-2009, 09:38 AM
massls1guy's Avatar
There was a thread where blocking off the heater in/out on the pump caused engine temp problems. I searched but can't find it.
Here's one other thread on the subject:
https://ls1tech.com/forums/generatio...ter-hoses.html
Old 09-02-2009, 08:35 PM
nemss1's Avatar
Never had probs with mine. My temp isnt affected when tested on tuning software
Old 09-02-2009, 08:42 PM
eseibel67's Avatar
Isn't a little "U" shaped bypass hose the easiest solution instead of blocking anyway?
Old 05-27-2010, 08:09 AM
Mongrell's Avatar
Any more input?
What about drilling a couple of small holes in the t-stat to allow a small amount of bypass flow?
Old 05-27-2010, 02:39 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
^^^^ This is how I have mine
Old 05-27-2010, 07:45 PM
S10xGN's Avatar
FWIW, if you want plugs, they tap out to 3/8" & 1/2" NPT. I have the hoses run to my Vintage Air Gen III, but the "heat" valve remains closed (in effect, plugged) 90% of the year and I've had no problems...
