Help ASAP! Clutch not disengaging, trying to fix it right now need help
Old 09-01-2009, 07:48 PM
01 Trans-Am WS6's Avatar
Default Help ASAP! Clutch not disengaging, trying to fix it right now need help
I finally was able to bleed the slave cylinder, now the clutch is not disengaging. When the car is in 1st gear with the clutch to the floor, the wheels are still spinning, when I lift the e-brake up it grabs the rear wheels and stalls the car out. What can it be now?
Old 09-02-2009, 12:53 AM
charlie c5's Avatar
Im assuming the car is in the air,?? Put the car back on the ground and try it. Worth a try.
Old 09-02-2009, 01:09 PM
Gen414's Avatar
If it stalls when you hit the brakes, the PP is not disengaging.
What setup are you running? Clutch/PP new/used, etc...
Old 09-02-2009, 09:11 PM
NAVY99B4C's Avatar
Default disengauging
You could need a longer cylinder on your throwout bearing. If you take the trans back off and put the bellhousing back on measure from face of the bellhousing to top of clutch fingers. Then put the stock clutch in and see if they are the same measurement. You will need to know that measurement if you order one like mcleod bearing.
Old 09-03-2009, 01:35 AM
NVM thanks for the help guys! We just took it apart and back together again lol
Quick Reply: Help ASAP! Clutch not disengaging, trying to fix it right now need help
