4l60e low roller cluch? limp mode? or?
Old 09-02-2009, 10:56 AM
eddly's Avatar
Default 4l60e low roller cluch? limp mode? or?
Ok so i am having some weird issues..... i have a 2001 Chevy s10 with a 4l60e i just rebuilt with a new forward sprag and a rebuilt pump. When i have the truck on the lift and in Drive i hit all of the gears w/o any issues, then set it on the ground in Drive the truck acts like its barly in gear, little movement with WOT. My line presure does not change in any gear(limp mode?) 100psi no matter if 1 or reverse..... what am i missing here......and also what does the low reverse clutch do?? HELP ME PLEASE!!
Old 09-02-2009, 02:30 PM
eddly's Avatar
lol anyone?
Old 09-02-2009, 02:41 PM
LS1Tech Sponsor
performabuilt's Avatar
The Low/Reverse clutch is only on in manual low one and reverse. If you are talking about measured in the port line presure i would say you have a massive internal leak or a stuck regular vave. Electronic limp mode etc would have no effect on reverse.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 09-03-2009, 07:29 AM
eddly's Avatar
yea i was checking pressure at the port above the shift linkage..... i will try to hit you up on yahoo messenger today
