What are you guys using for fuel delivery?
Haven't done a whole lot lately in the GEN 1 V department recently. What ar you guys using for your setups? Same old boost a pumps? Intanks? Inlines? Externals?... Just wondering if anyone has stepped up and made something "GOOD".... that doesn't fail every other week. CHeap or expensive, doen't matter. Just curious...
Everything stock, im thinking of dropping a 255wally that should hold me on a 150-175 wet shot you think smoove? i don't even wanna bother spraying on the stock pump if im making basically 430 n/a.
-Vinny
-Vinny
Thats kinda why I posted this,... I
'd like to hear of more options for these cars. The tank,... isn't THAT fun to drop, and the pump module, is funky as hell. Not a big deal,.. but, not everyone can do that or has the means too. I have worked with every type of BAP,... I have had atleast ONE issue with them all at a point. I was under the impression that EPP or someone had a more simple fueling setup, for the average bear. I could be wrong.
Looking for solutions, and to see if anything is new out there.
Let me know if you need any specs/steps to remove your tank or anything man.
-J-
aka ...smoove
Thanks for the info Jamie, i heard the tank is a real pain in the *** i can only afford to be stock bottom end and since theres no sensible turbo setup i don't see myself passing 600rwhp which would be a blast on a stock bottom end lol Racetronixs makes a plug and play 255 but its like 400bucks. Is it that difficult to adapt a 80 dollar 255 on the bitch? lol
If you have a gas tank schematic / steps to drop the tank or **** ill have you do it when i recover ive been a broke man! twin disk sitting under the desk for a few weeks now I hope i can get it ready in time for the 1 mile i still need tires and brakes. FML
I think BAP is a retarded band aid to have especially with people making power with a stock fuel pump.
Been talking to Aeromotive tech & there saying I have to go to a -12 feed line & get the pump closer to the tank. Also wanting me to put a cooler in the return line & larger Vent in the tank
I have to drop that F**kin tank again sometime this winter & spend another grand in parts with all the new an-12, fittings & cooler ect.
Yes, and been having some issues with loss of fuel pressure sometimes.
Really, racetronix has a kit for these cars? Didn't know that. Was wondering something like that, as opposed to just build your own walboro setup. My racetronix vette setup had a hotwire plug and play kit. Seemed to work well. Stopped keeping up with my setup around 5500rpms,.. over 7xx. So 600 will be fine with that. You could do an inline pump as well, an inline 255 would work. Kinda how some of the procharger and magnacharger kits used to be or are currently.
Let me know whenever you need something man,..we'll get you pointed in the right direction.
Well that sucks. Doing a -12 feed and -8 return on my vette with a magnafuel pro series 750 fuel pump. Magnafuel regulator, bosch 160 pound injectors, acceleronics versafueler. I was originally gonna go with an aeromotive but, didn't like the supply rating and had heard just a couple of stories like yours. Some guys locally done well with the magnafuel, making big power, for long periods of time. Plus, they do have a good warranty setup. Check it out.
Im running a $6k completely custom fuel system with a Magnafuel 750 pump, a really nice custom fuel cell with sump located in the spare wheel well, all stainless braided hoses w/AN fittings,and billet fuel rails. I know im forgetting alot of things.
True, Jamie what do you think about going e85 i wonder if a 255 and inline will be enough or 2 255s would be required i know it would only be about 10-15hp on motor but i would look foward for the torque #s and on bottle it would be pretty **** some timing with a 150 making the power of a 175shot basically?
That was everything out the door including labor and tuning, really the fuel cell absorbed alot of the cost becuse they litterally made it from sheets of aluminium, turned out real nice thought. It fits really nice in the sparer wheel well. Ill try to get some pics of it later.
Nice, thanks dawg. In tank? I'm gonna shoot to there site in a minute and see if they advertise something. Thanks C-money
One would not be enough. E85, as you mentioned wouldn't net tons of power NA as you mentioned but, maybe on the juice you'd be able to run more timing I guess(asu mentioned).
The simple addition of another pump alone I don't think would be enough but, I have not experienced enough with e85 to know for sure. You'd also need a larger feed line, as well as much larger injectors,.. i'd say 60-80pounders on a NA setup running e85. The reason why my fuel system is soo large now, is because I have full intentions on running E85 myself. You need a 700hp gas system to handle a 500rwhp e85... you need a 900hp gas system to handle a 700hp e85 setup... I think is a general relative rule of thumb.
Maybe look into a couple of the Bosch 044 fuel pumps... you'd still need to make your own lines but,... I believe you'd have to for that kind of supply.
Sounds crazy man.
Spraying 125 on the stock pump making about 380-400whp NA depending on the dyno. No problems yet!
Exacty. Look at the majority of dyno graphs when spray hits. Mine, dipped way lean on the hit,.. picked right back up but, regradless, it's brutal for that instant. Standalone(don't think vin diesel) fuel cell and pump for the nitrous alone is the ticket. Run race fuel in the mini tank, a 255, regulator, good to spray whatever you can throw at it, without touching your lines.
Were doing a nitrous outlet fuel setup on this car....
