got a question about BMR springs
Old 09-02-2009, 08:53 PM
bongva's Avatar
Default got a question about BMR springs
If these springs are not low enough for my liking, can i do the hose mod for the rear, and perch mod for the front? shocks are new from Oreilly's.
thanks,
Lee
Old 09-03-2009, 02:05 AM
mediocrels1's Avatar
u can just cut them if your going for looks
Old 09-03-2009, 08:20 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
thanks,
Lee
Lee, yes you can still do the hose mod to the rear and the perch mod to the front but i really don't recommend it. Doing those mods will make it hard for your shocks to do their job correctly. The mods that you mentioned will make the drop 2.00". You will need better shocks designed for that much of a drop. You are going to run into other issues, ground clearance, torque arm clearance to tunnel, tire clearance etc. Most of our customers have found the 1.25" drop to be acceptable. If you have any other questions please give me a call.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 09-03-2009, 04:08 PM
JD_AMG's Avatar
thanks,
Lee
The "lower perch mod" in the front is only on koni single adjustable shocks, all other shocks do not have a way to lower the perch (from the factory).
And doing this on the konis with lowering springs is a good way to blow out the shock, this is meant for stock springs only.
Old 09-03-2009, 08:54 PM
bongva's Avatar
Ah ok I see. Guess if its not low enough I will live with it. LOL
Thanks to all!
