New Products Showcase Come inside to see the newest hardware!
UMI Performance Releases 1.250" Rear Drag Bar
Old 09-03-2009, 03:56 PM
UMI Performance's Avatar
Default UMI Performance Releases 1.250" Rear Drag Bar
Hello Members,
UMI Performance now offers 1.250" solid chrome moly drag bar for the 82-02 F-Body. The kit is supplied with everything needed to install it. This kit is a bolt in kit with welding recommended/needed. This means the kit can be installed in your driveway or garage and driven to the nearest shop for the little bit of welding that needs completed. We were able to use factory holes for mounting and used heavy duty u-bolts to attach the bar to the axle tubes. The mounting brackets feature grip teeth CNC machined into them to prevent the bar from rotating on the axle tubes. Please take a look at the pictures below and the link for more information.
Link- http://www.umiperformance.com/catalo...ex&cPath=7_114
Old 09-03-2009, 04:44 PM
LS1 SPEED's Avatar
Default nice
look forward to putting one on next week
