i want to beat a stock C6 Z06 with 7psi!!!
Old 09-03-2009, 06:01 PM
KILLER-LS1's Avatar
Default i want to beat a stock C6 Z06 with 7psi!!!
well guys, im almost done with my front mount t76 build, and after driving the new C6 Z06 vette, i want my car to be that fast, or faster! i think they put down about 480ish to the wheels with a tune and CAI so as long as i make that or a smidgen higher i will be stoked! basically i have the ebay hotside kit with a t76, FMIC,50mm BOV, 38mm wastegate, and its going on a speed density tune. It has 50 lb/hr MSD injectors walbro 255 intank pump, MSD coils & wires, a TR 224/224-114 LSA cam, comp 918 springs and comp chromoly pushrods with titanium retainers and locks. Im going to be running an open downpipe and this is all through a T56 with a spec clutch, stock rearend with 18" rims.
painless wiring meth kit in a few months....
soooooooooooo, you think ill be able to beat a new z06 vette on 7psi?!?!
(assuming I can hook? lol)
Old 09-03-2009, 08:55 PM
KILLER-LS1's Avatar
i know someone has raced a z06!! come on guys!!! or at least dyno'd a setup like mine...
Old 09-03-2009, 09:02 PM
OUTLAWZ RACING's Avatar
your gonna need about 550 to make up for the weight diffrance.
Old 09-03-2009, 09:05 PM
KILLER-LS1's Avatar
hmmmm maybe i should put the 10psi spring in i dont care about dyno numbers, i just want my car to have that kind of slam-your-***-into-the-seat feeling that i got in that car!
Old 09-03-2009, 09:27 PM
black98ws6ta's Avatar
Your car has the potential...It may not do it on 7 psi, but it should make 550 rwhp or so around 10.
Old 09-03-2009, 09:33 PM
sujomatt's Avatar
i thought it said slam-in-your-*** .. i guess im a perv haha
anyways, i think if u have the meth kit with that cam and a GOOD 2bar tune ull be right there with them.
Old 09-04-2009, 12:02 AM
01Z28Camaro's Avatar
I've beat them with my cam only c5z, landed hard on them with the camaro on 8 psi.
Old 09-04-2009, 08:42 AM
Super Slow SS's Avatar
I think you have a good chance, I mean most people that own them wont do more than a 4th gear pull on the interstate, and arnt really "driving" enthusiast. But as for the Slam-your-*** syndrome .. the turbo will handle that for you in a much better way than an N/A car will.
Old 09-04-2009, 09:07 AM
Hi Volume's Avatar
leave on his *** and spray a meager 150 shot...
Old 09-04-2009, 10:45 AM
cause4panic's Avatar
I would up the size of those injectors or spray a large amount of pure meth on it.
Old 09-04-2009, 11:02 AM
67Firebird455's Avatar
Agreed, 50's aren't gonna take you very far. Mototron 60's will get you there @ 58psi pressure. Get a set of #317 heads to lower the compression just a hair, while benefiting from less restriction (remember boost is a measurement of restriction in a pressurized system).
Quick Reply: i want to beat a stock C6 Z06 with 7psi!!!
