116 fuel vs 93 octane
Was running 93 octane in main tank and 116 in standalone. Was told to run 116 in both on a 300 hit. What do you think that will do to the existing tune up will it make it rich or lean? And by how much ? My plan is to make some passes and pull all the plugs but just wanted to know if anybody had a clue what way it should go. And timing can you run more or less with 116 ? Thanks mark
It looks like Q has more oxygen, but not sure if it's necessarily beneficial for nitrous use? I emailed the tech department with specific questions regarding our application so I'll let you know as soon as they respond.
