what do 3.23s run rpm wise at 70, mph?
Old 09-04-2009, 09:05 PM
redws618's Avatar
Default what do 3.23s run rpm wise at 70, mph?
i need to find out what gears i have and do not have the factory tags on the door or glove box, at 70 mph i run at 2300, any ideas or opinions as to what i have?
Old 09-04-2009, 09:10 PM
redbadss's Avatar
im between 2000-2100 at 70mph. i got 3.23s from factory. sounds like 3.42s swapped if you are an auto.
if you're m6 im not sure maybe 3.73?
Old 09-04-2009, 09:12 PM
redws618's Avatar
yeah sorry, im an a4, 02 ws6.
Old 09-04-2009, 09:19 PM
redbadss's Avatar
http://www.f-body.org/gears/
this site might help you out. i checked different gear ratios and with 3.73s you would be 70mph at 2400rpm. if you had 3.42 you would be 70mph @ 2200rpm.
Old 09-04-2009, 09:27 PM
redws618's Avatar
i guess i really dont understand that graph, they don have my car anyways? maybe i just dont how to do it, any one else with their rpms and gears at 70 mph?
Old 09-04-2009, 09:49 PM
01ssreda4's Avatar
sounds like you have 3.42s. 70 with 3.23s is about 2050-2100
Old 09-04-2009, 10:03 PM
blackz28x07's Avatar
glad i looked at this thread. I'm right around 2250-2300 at 70 mph
Old 09-04-2009, 10:45 PM
redws618's Avatar
thats right where i am at, is there a for sure way to know other than taking the cover off?
Old 09-04-2009, 11:01 PM
01ssreda4's Avatar
jack the rear of the car up, put the trans in neutral. I had a buddy turn the back wheel till the valve stem was perfect at 12 o'clock. Mark 6 o'clock on the driveshaft which is facing to the ground where you are looking. Turn the driveshaft until your buddy signals the valve stem has made one complete revolution and is back in the exact same spot. If the driveshaft has turned about 3 and 1/4 you have 3.23s. If it turned about 3 and 1/2, then you have 3.42s.
Old 09-05-2009, 10:29 AM
Pontiacerator
RevGTO's Avatar
You can find out what your car originally came with by checking the RPO code sticker on the door. If it's GU2 it was 2.73. If it's GU5, it was 3.23.
According to the f-body.org chart, 2200rpm @ 70 = 3.42s, 2400rpm @ 70 = 3.73s. You seem to be in between, for which there's no gear set ... so you probably have one of the above.
Old 09-05-2009, 11:51 AM
poorhousenext's Avatar
If you want to try backing into what gears you have, try the link below. Since rear tire dia can make minor to major difference depending on dia, look it up on mfg's website, are measure them.
http://www.apexgarage.com/tech/gear_ratios.shtml
Old 09-06-2009, 05:33 PM
CHRRRIS's Avatar
I'm pinned at 1950 going 70 with 3.23's A4. I like it.
Quick Reply: what do 3.23s run rpm wise at 70, mph?
