Torque arm poly bushing and trans poly bushing
Old 09-04-2009, 10:06 PM
jester ls1's Avatar
Default Torque arm poly bushing and trans poly bushing
I just replaced my torque arm bushing and trans bushing, my car is a 98 with 63,000 miles. My shifter was jumping up when I accelerated so I replaced both. Now I feel some vibration, is this because everthing is so tight? When I hit the gas it does feel alot better with quicker throttle response because there is no flexing up and down with the arm. I did set a jack under the transmission so nothing changed. Is this normal?
Old 09-05-2009, 07:40 PM
Schnell's Avatar
If you used ES poly you made a mistake and it won't get any better. Prothane makes a MUCH better poly tranny mount.
Old 09-05-2009, 09:11 PM
xbcrguy182x's Avatar
That sounds like a poly mount. Poly is much harder than rubber, so that's why you feel the vibration. After a while, you will get used to it.
Old 09-05-2009, 11:37 PM
99Bluz28's Avatar
Thumbs up
Sorry, but not true.
With the ES poly trans mount if you grind the 2 preload bumps flat, there's very little vibration at all. And as far as Prothane making a better trans mount, I really can't say since I've had a ES trans mount on my car for over +6 years with no problems.
Old 09-06-2009, 05:23 PM
jester ls1's Avatar
Thanks guys seems to be better now after a few drives, I think it was just to tight and needed to be broken in. But ya the stock rubber was a lot softer and dry rotting.
Old 09-06-2009, 07:28 PM
Schnell's Avatar
My experience with ES has been horrible. To the point of the mount breaking completely (picture) and then after I replaced it with another the next one was so stiff and harsh I couldn't do it. Hell it might as well have been solid! Prothane was 100% improvement over the ES.
Old 09-07-2009, 02:55 AM
BluShadowSS's Avatar
I have poly trans mount and had alot vibration at first but feels better now that its broken in more.
Old 09-07-2009, 06:48 AM
jester ls1's Avatar
Both the torque arm and trans mount bushings are poly red energy suspension. What does (ES) mean?
Old 09-07-2009, 08:28 AM
Schnell's Avatar
ES=Energy Suspension.
Old 09-07-2009, 11:00 AM
jester ls1's Avatar
DAMN!!
Quick Reply: Torque arm poly bushing and trans poly bushing
