hp limit
hp limit
I have read for years that the 97-99 rod bolts were a "weak link" in high hp power levels.
With the latest blower pulley change, and misc. improvements, my 98 SHOULD dyno in the 625-640rwhp range.
As long as I keep the rpms down in the 6200 range, do I REALLY have any concerns of it "letting go" on the dyno?
Anyone have their rod bolts let go??
I'm completely stock on the bottom end.
From everything I've read, the ringlands go from detonation from being lean or too much timing (read; bad tune) The tuner I use has a lot of experience with SC, and likes to tune very safe even if it leaves a little bit on the table.
I DON'T want to squeeze every little bit of hp out of it at the expense of reliability
I asked about the rod bolts because I hear a lot of references to them being a weak link, but almost every engine issue I read on SC engines is ringlands
8 sec potential, 12 sec slip
Well good luck then. All I can say is over the years, I've seen a ton of stock ringlands let go- WAY more pistons than rod bolts. And your statements are totally contradictory. There is no way you will make 625-640rwhp reliably and safely on stock pistons.
And there are a LOT of FI LSx engines in the 600+ rwhp on stock bottom ends, I would just like to be one of them, and since I don't hammer on my car very much, maybe my chances are improved
Yeah... pretty wild... you must have missed the part where it shows the 2.0 60' time. Last I weighed it it was 3800 without me or the cage in it. Full interior... AC... speaker box and amps... leather... fully loaded.... 9". Its deffinitely not a slot car RX7. Last time out it lifted the tires with the 6spd, 60' to a 1.6, but I lost 2nd gear..... hydraulics couldnt keep up... still went 11.3 @ 128 fiddle f'in around to get it into 2nd.
Still doesnt "jive"?
Running over 600 HP is just a time bomb on stock internals. "there are lots of them" well there might be. if you do ONE run on it and get it there, but who has a car with that kind of potential and doesn't want to use it.
and yeah. for a 650 HP car 11.4 isn't all that fast. but there are lots of differences in drivers, and how it's driven. Manual 6 speed. can kill a great time with just a few little mistakes.
60' doesn't affect mph at the end of the 1/4.
My 60' was 1.82 on 7 year old 245/50/16 Nitto DR's and it pulled 99.9mph in the 1/8 mile on the 128.3mph run. 11.42 et road race car
Nonetheless your car should be running mid 135mph with that kind of power. Obviously your car wasn't working properly.
You said "number", sorry, you didnt specify if your attempt to argue about your point was about MPH or ET.
I actually find it comical that youre comparing your 11.4 @ 128mph in a RX7 to the same time ran in a F-body.
Until then....... your argument is nothing but apples to oranges.
we have a local guy stock 03 Z06 neven had a valve cover off that makes 717rwhp and runs 9.7's @ low 140's runs a twin turbo at 13psi. He has a couple of seasons of bracket racing on his motor.
Not saying this is normal or what you can expect but he somehow does it.
Exactly.. I had eased my GTO to a decent 60', then broke loose like I was on ice on the shifts. Looking at the 60', mph and ET, something didn't seem right for the power it was making, but looking at the 330' and such showed it launched fairly hard then lost it after that. Add in the fact that it is a manual and there are far too many variables to call BS on his numbers. Too many "experts" here when it comes to criticizing others...
