04-08 Grand Prix/MCSS/Impala Thottle Pinout
Accelerator Pedal Position (APP) Sensor
Connector Part Information
15326829
6-Way F GT 150 Series, Sealed (BK)
Pin
Wire Color
Circuit Number
Function
A
PU
1272
Low Reference
B
L-BU
1162
APP Sensor 2 Signal
C
TN
1274
5 Volt Reference
D
BN
1271
Low Reference
E
D-BU
1161
APP Sensor 1 Signal
F
WH/BK
1164
5 Volt Reference
If you hold the harness plug with the wires away from you and the latch on the top, Pin F is on the left, pin A is on the right
15326829
Pin
Wire Color
Circuit Number
Function
A
PU
1272
Low Reference
B
L-BU
1162
APP Sensor 2 Signal
C
TN
1274
5 Volt Reference
D
BN
1271
Low Reference
E
D-BU
1161
APP Sensor 1 Signal
F
WH/BK
1164
5 Volt Reference
15326829
Pin
Wire Color
Circuit Number
Function
A
PU
1272
Low Reference
B
L-BU
1162
APP Sensor 2 Signal
C
TN
1274
5 Volt Reference
D
BN
1271
Low Reference
E
D-BU
1161
APP Sensor 1 Signal
F
WH/BK
1164
5 Volt Reference
15326829
Pin
Wire Color
Circuit Number
Function
A
PU
1272
Low Reference
B
L-BU
1162
APP Sensor 2 Signal
C
TN
1274
5 Volt Reference
D
BN
1271
Low Reference
E
D-BU
1161
APP Sensor 1 Signal
F
WH/BK
1164
5 Volt Reference
Just FYI the MCSS/Grand Prix/Impala pedal did not work with the 06 TBSS LS2....original pedal plugged in and worked fine though...so I guess I'm gonna have to suck it up and fab a bracket for it....
