Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
SB2.2 Build??
Old 09-05-2009, 06:09 PM
charlie6178's Avatar
Default SB2.2 Build??
any body else on here played with the Nascar SB2.2 stuff???
i'm building one for my 1971 Nova
Attached Thumbnails SB2.2 Build??-dscf0155.jpg   SB2.2 Build??-dscf0156.jpg   SB2.2 Build??-dscf0157.jpg
Old 09-05-2009, 06:33 PM
stumprrp's Avatar
nasty man, i had the sick idea of a SB2 motor with an F2 procharger on top, that would be a SICK sound at 9500 RPM and would probably run like high 7's in a 2800lb car.
Old 09-06-2009, 02:12 AM
yeah i'm doing it 372CI 12.5 to 1 with 2 850cfm quick fuels..
it's going in a drag radial nova. aslong as it runs a 9 i'll be happy.
no matter what it's gonna see more street time than track anyways....
Old 09-06-2009, 12:17 PM
hotrodscrap's Avatar
Beautiful motor man!
-SS
Old 09-06-2009, 12:24 PM
hashtagBMW
Speed Density's Avatar
An LT1 guy built one a couple years back for his 95Z. SB2.2 stuffed ontop an LT1 block w/ a directport. Was amazing but never run.
Old 09-06-2009, 08:23 PM
yeah i can't believe the power these motors make, and how cheap you can get everything! the parts for theses things are a dime a dozen!
i figured somebody on here had played with one over the years!
i saw that 95Z, i think he did end up getting it running at some point??
Old 09-06-2009, 10:03 PM
Josh@KY-Turbo's Avatar
I know some local guys that run the SB2.2 stuff in thier cars. They are nasty on the Bottle. 9's should be easy.
My only issue with the SB2.2 stuff is getting the compression low enough to be able to run a decent amount of Turbo derived boost. It not a big issue if you are willing to run Alky. That just kinda sucks on the steet.
Entry price's varies on the engine's depending one where thay come from. Parts after that can be bought very reasonably.
I have been eye'ing a couple of these engines for my 70 Camaro street car project. It would be a blast with a stick and steep gear.
Old 09-07-2009, 12:47 AM
oh yeah, it's gonna be a blast no matter what. the car i'm doing is still going to be a leaf spring car, and stock sub frame, drag radials, and my goal is to have a heater, and power windows
as far as getting it to the ground.... i'm in the process of building a chromoly fab 9, with a strange center section, and i had some old lenco stuff layin around from my dads old blown alcohol car.... so looks like we might be runnin a stick after all!
Old 09-07-2009, 03:06 PM
JUICED96Z's Avatar
9500RPM and a F2? I think the main problem would be having parts last....... once you start making power with a power adder you need strong parts and those tend to not like RPM.
Old 09-08-2009, 09:04 AM
SneakySSnake's Avatar
I think they are pretty impractical for a street car. I would much rather build a 434 sbc, or better yet a BBC! Cool setup though, what did all the parts run ya if you dont mind me asking?
Old 09-08-2009, 12:02 PM
slooter's Avatar
Default Sb2-2
I'm putting one in my 2002 camaro
Attached Thumbnails SB2.2 Build??-im000310.jpg   SB2.2 Build??-im000309.jpg   SB2.2 Build??-im000308.jpg
Old 09-08-2009, 11:10 PM
Tweaked Zed's Avatar
Been running a 427ci SB2.2 for 3 years now with a T56 behind it and on pump gas. Fun ride for sure! Dynoed 758rwhp corrected. Although, I'm thinking about selling the complete top for something else with pressurization. I'd let go of everything needed (complete heads, welded and ported intake, valley cover, fuel rails, manton pushrods, isky lifters, sheet valve covers, 2 cammotion cams, lemons stepped 2" - 2 1/8" headers for a 4th gen) and all you would need to buy are pistons for your normal sbc block and some gaskets. Email me at tweakedz@telus.net if anyone's interested. And not really impractical for a streetcar. Still runs 2000rpm on the highway at 75mph with 4.89 gears and 29.5x10.5s. Just enough lope to draw a crowd though. LOL.
Old 09-09-2009, 06:20 AM
alottaboost's Avatar
That is insane!!!
Old 09-09-2009, 08:03 PM
good god you guys are doing some baaaad SB2.2 stuff!!
i'm glad to see it's working out tho!
i was a little worried i was kind of on my own on it.
Old 05-01-2018, 05:55 PM
dawgs74's Avatar
did you ever get that sb2 running in that nova?
Old 06-08-2018, 09:40 PM
No it's still all sitting. I left the LS1 in the Nova and made it more of a pro touring car.
Quick Reply: SB2.2 Build??
