In line fuel system for Studebake Avanti LS1
Some progress on the LS1 conversion for the Studebaker Avanti.
Installation of prefilter, Walsbro GSL 392 fuel pump, and Corvette filter/regulator along the rear X-member, driver's side. The RobbMC filter is large and 40 micron, Walbro pump is 255 lph, the Napa Corvette filter/ regulator is for 58 PSI. Used Goodyear fuel injection hose, and fuel injection stainless clamps. Will run the fuel return line above the pump and prefilter.
You can see the aluminum drive shaft in the top right of the photo. We had to put a conversion U-joint at the rear, going from Saginaw 3R in the drive shaft to a 1350 at the Viper pinion.
