Based on those pictures I think they would still work. A hammer and a little bit of pounding would straighten those back up.
Hope that helps,
Ryan
Ryan, while you're here I've got a question for you. I currently have a set of your weld in SFCs. I haven't put them on because I can't find someone with a welder and a drive-on lift. Is this an absolute must? Or can they be welded on with a post-lift?
The suspension must be fully loaded and level while welding. For a post lift we recommend to sit the vehicle down on jack stands or place cement blocks under all four tires... then complete your welding on the ground.
