LM2 even more restrictive than what I had before?
I replaced my stock catback which had a hooker aerochamber welded into it for a SLP loudmouth II looking for a big hp gain considering my mods. After getting the catback, the first thing I noticed is the damn thing goes down to 2.5 inch ID in the muffler/resonator. Is this STILL restricting my exhaust and does anybody have LM1 vs LM2 dyno numbers. I'm probally going to replace the muffler with a quieter one too, any recomendations besides Borla XR1. Thanks.
Should I get a Hooker aerochamber 3" catback since it doesn't go down to 2.5in, I searched and found some dynos where people were getting slightly less HP than expected and had the LM2 as their exhaust.
so i am running LTs, ORY cutout, and a rotted out 80 series flowmaster.
i was thinking about the LM2 to replace the cutout / muffler i have now......but was thinking of a 3 " i pipe, and 2 single chamber flowmaster mufflers before the tips....
eliminating the LM2 bullet muffler.....
and i going to lose power ?? LM2 over the cutout ? or the flowmasters over the Lm2 ?
can't have power loss !!!
how about 1 single chamber flowmaster muffler in the i pipe......some say there may be ground clearance problems.... but if you can fit a bullet muffler, this should fit...
will it affect the sound if the muffler is that far forward in the system ? it shouldnt right ?
I think the Hooker and Loudmouth II would be the same HP if not giving a 5hp favor to the hooker. Plus it's not a ticket magnet when cruising. I AM concerned with every hp possible because it may not be much but it adds up in the end.
Took the muffler off today to verify, HitmanWS6. Actual ID is about only 2 3/8 inches. I was wondering if anybody knows the ID of the Borla XR1 and if it soulds better as well. I cut the exhaust crossmember since the Y-pipe was resting on it and readjusted the exhaust and the sound is acceptable now.
LM2's are not going to make you lose power, They are a straight through design bullet muffler.... Your not going to see really any gains by swapping to a LM1.... Bullet style mufflers flow better than Chambered but chambered give a distinct sound like flowmaster ect.... Just my .02
I'm still trying to convince myself about the muffler flowing enough air but am also trying to learn about exhaust flow, design, sizes ect.
If the 2.2cfm @ 20.4in/hp guideline is true, for a car that makes 400rwhp/.82 for drivetrain loss through an automatic, that is 487 rough hp. For less than 1% loss in power the car would need a exhaust that flows 1071 CFM. The 3 inch mandrel piping on all the aftermarket exhausts flow about 980-1000CFM, 3.25 inch or bigger would be oversized until the car makes over 560hp.
(these are very rough numbers)
2.5" dumps, 618hp
The mufflex 4 inch pipe will handle about 795hp.
3.0" dumps, 890hp
4.0" open collectors, 1600hp (Pro stock cars run these and make about 1500hp)
The stock cats flow 567 CFM combined, only flowing 258 non restricted horsepower. My 2.5 inch carsound cats were tested to 746 CFM to flow 339hp.
The loundmouth 2 in question should flow about 680CFM (2 3/8 ID). To the guideline, that is way too small, and flows 66 less CFM than the carsound cats. Compared to a completely non restrictive exhaust, this exhaust is costing me about 16-20hp, but over just a LM2 Vs 3.0" straight pipe it will be much less.
So LM1 vs LM2 should be at least 4-5 hp which is a lot considering all aftermarket exhausts add about 10-15hp. (33% more power) But not as much that I was thinking.
2.5" dumps, 618hp
3.0" dumps, 890hp
wow, thats way too much "science "
if someone is worried about losing 5 hp... then stick with what you have or do more homework before buying something different.
5 hp can't be that important... + / - 5 hp is acceptable...
if it was 25 i would be worried.
I searched a lot before getting my catback but never saw anybody mension the very small inner diameter, I got the SLP LM2 because the hooker catback has been out of stock for months. If it's 5hp now, who knows how bad it will be restricting after my heads, maybe 10+, for hp that I thought I was paying for to have, its a big deal to me.
I just would like it to give at least the same numbers as the hooker would have gave me for less money.
So I guess everybody that told me it wasn't costing me any horsepower has nothing to say now after seeing those pictures? Or maybe they themselves had LM2 mufflers and didn't want to believe it.
