Turbo thru GM intake.
Old 09-07-2009, 11:52 AM
Jimbo1367's Avatar
Default Turbo thru GM intake.
Do anyone know if you can use a composite GM or FAST intake on a Turbo setup ? If so, what would be a safe limit for boost ?
Thanks,
---Jim---
Old 09-07-2009, 01:53 PM
91ZLS6's Avatar
Check Forced induction. GM intakes will last longer then fast.
Fast has 6 screws holding it together, it would always have a negative pressure in it n/a in part drawing the top shell downward.
In boost situations they will work, but they have a limit before you will blow the top shell off.
Old 09-07-2009, 02:12 PM
MeanYellowZ's Avatar
most guys have had luck with the stock intake < 20lbs. I have ran some to 18 without issues. I would say if you REALLY plan on running above 15-16 a lot, you would want to look into something made of metal
Old 09-07-2009, 03:21 PM
gnx7's Avatar
Stock LS6 intake has made 1000rwhp in plenty of combos on here. Cheap and effective. The rear 2 cylinders should have injectors that flow a few percent more than the rest as those tend to lean out.
Old 09-07-2009, 05:02 PM
Jimbo1367's Avatar
Thanks guys.
So I need some input then. Since I have the possabily of a Turbo down the road. I should go LQ4 vs LQ9. HUH?
Old 09-07-2009, 08:54 PM
91ZLS6's Avatar
Thanks guys.
I hate to say it, but do a search in the Forced Induction section. Its been covered 104353409583409 times.
Old 09-07-2009, 10:16 PM
Jimbo1367's Avatar
thhanks guys. Just what my wife wants. Me spending MORE time online.lol
Quick Reply: Turbo thru GM intake.
