New GM master install question
Hey, It says that the unit comes pre-bled from GM. Here is my dumb question. When I install this do I need to bleed the whole system or just remove old, install new and go? I'm only replacing the master at this point. Thanks
I did the master and slave at the same time, but the master did have fluid in it and was supposedly already bench bled. The slave however was dry. I hooked up a motive bleeder with a slave extension and bled all the air out. I think you'd be ok but it shouldn't hurt to bleed it.
However, I'd bleed it afterwards just to be sure there is no air trapped anywhere in the system.
