different carrier in my stock housing.
i know i can swap the carriers no problem. i currently have the stock 2 series in there, but i want some motive 3.90's and they dont make them for the 2 series carriers. SO, when i do the swap do i reuse the caps in my stock rear or do i need to use the caps that come from the donor rear. i also assude that i will have to start from scratch when it comes to shims right.
And what about the 1/8" steel disks that are on the sides of the diff? dhich set do i use? the stock two or the two from the donor rear?
Jeff
Caps stay with the corresponding housing as jaws stated. Typically the steel discs are a good starting point for setting up a rear end with new bearings. If using old bearings I have found that there will be some slack during reassembly so I add a very thin shim in with the steel discs to pick up the extra slack in the old bearings.
it's called sharing information pal. I didn't see anywhere that he said they were his... or yours. afterall they came out of HIS photobucket account.
but if it makes your panties wet, then thanks for you help.
If you know him and are just pokin him in the ribs then forget the attitude heavy response i just made, but if not, then get a grip kid.
to 01ssreda4,using my pics and presenting them as though their yours ? Guess we found out about you ! Normal professional courtesy would dictate "photo and data courtesy of"
Are the pics in post 6 correct? can anybody tell me positivly?
i just looked at my carrieir that i bought that was supposed to be a 3 series and it looks like the one labeld two series in that pic.
