is 94 z28 steering w fit 2002 z28.. plz
hie guys i just wanna ask 1994 camaro steering wheel can fin 2002 camaro ?
is there any difference between v6 and v8 steering wheels
because my steering wheel is not good and airbag out
so i got used 94 steering wheel with airbag and wanna swap it
if u have any pictures ill appreciate it
best regards and goodluck
The steering wheel will pysically bolt right to your 02 column . While you can mount the airbag and not plug it in (I have done this with 0 problems over the years ) I would not advise plugging it in ( if the plugs are even the same ) and mix matching airbag components for obvious reasons . Im the king of making anything work , but I wouldnt want anything to do with a powered up airbag that really isnt supposed to be there .
