Moser 12-bolt questions...
My buddy is swapping a Moser 12-bolt into his 02 Camaro and we just had a quick question.
Is the pinion flange on these rear ends the same as the 10-bolt? Meaning, will the factory driveshaft bolt right up, or do we need to change the flange on the driveshaft.
Also, does the driveshaft need to be shortened or will stock length work?
I did the same conversion, just had a local shop put a 1350 ujoint in it and it bolted right in. I was concerned the stock length was push in too much on the trans (putting it in a bind) so I had a shop shorten my trans yoke 1in. Made it alot easier to get in and out.
