bolt size
bolt size
i see on sites that adjustable panhards and lower control arms use 3/4'' rod ends. but the stock bolts are 12mm(1/2) right? how does that workout? a sleeve used to down size the hole?
do the spohn ends have a sleev running through them for the size bolt needed and then the spacers butting up against the rod end to keep from moving or are the spacers actually going into the end as well? on the site it just looks like a regular spacer and not a step spacer?
http://www.spohn.net/shop/Replacemen...pohn-LCAs.html
these spacers will keep it from moving though right? also there not a step spacer correct?
