New LS1 Owners - Newbie Tech - What gears and stall to get?
View Full Version : What gears and stall to get?
corkynjimmy
09-07-2009, 10:40 PM
I just bought a 99 trans am and am about to order some gears and a stall. It has a fast intake and throttle body, ported maf, longtubes, true duals, tsp ms3 cam 237/242 .603/.609, 275/60/15 drag radials. Car is an a4 and has 3.23 gears right now. I was thinking a 3000 stall and 3.73's but Im kinda new to the LSx thing. What do yall think would be the best setup for me? Car is just a "whenever im in town" toy not a dd or anything. Also does anyone know any Good shops to get it tuned?
JeaneZ28
09-07-2009, 10:43 PM
3600 or 4000 stall
3.73 gears
Where do you live?
desertLS1
09-07-2009, 10:44 PM
Camming it before a stall is not a good idea.
With a cam that size, a 4000 stall is in order.
3.42's or 3.73's would be what id drop in.
JeaneZ28
09-07-2009, 10:47 PM
Sounds like he bought it like that.
corkynjimmy
09-07-2009, 10:51 PM
ya just bought it like this.....sorry forgot to mention im in the Dallas/Fort Worth, TX area
TAtoad
09-07-2009, 11:24 PM
3.73s with 3600-4k stall. gonna run good man
hitmanws6
09-08-2009, 12:20 AM
e mail yank with your setup, they will point you in the right direction. and 3.73 for gears
itsslow98
09-08-2009, 03:23 AM
4.10s or 3.73s with a 3600 stall at least. the car will roll out but i would also look into builind the tranny because its only gonna last so long depending how you drive it.
JackArse32
09-08-2009, 04:14 AM
if you're camming an engine just because, but not necessarily because you're going to be taking it to the track or pushing it. just for tooling around town, and just knowing that you have it.. would you still want to stall it?
TXZ28LS1
09-08-2009, 09:05 AM
3.73 and atleast a 4K stall for a cam that size
01ssreda4
09-08-2009, 01:03 PM
Good advice in this thread. I say 3.73s and a SS4000.
NC98Z
09-08-2009, 01:35 PM
Well the real question is What kind of stall is installed in your car now? It can't be stock with a MS3 cam in there or it would be undrivable to say the least. How high can you brake stall to? If you have a Vigalante, Yank or any top brand convertor in there now you can get it restalled alot cheaper than buying a new one. 3.73 for the gear ratio. 4000-4200 for the convertor if you plan to keep the car N/A. 3200-3400 if you plan on running giggle gas.
johnLs1camaro
09-08-2009, 01:52 PM
I have 3.73 gears and a 3500 stall. I love it, but I need more stall. I have a 4000yank im gonna throw in. So I say if anything go with a 3500 or higher, but Id really do a 4000 if I was you..
SOMbitch
09-08-2009, 03:19 PM
4k/3.73's
green28
09-08-2009, 04:33 PM
Thats what I'd got with, given the mods and cam size. Hell I might even go with that combo with the stock cam until I can throw a better bumpstick in.
corkynjimmy
09-08-2009, 04:46 PM
Stock convertor in there now.
doom brincer
09-08-2009, 06:17 PM
you have stock trans, watch what you doing. I think you should rebuild ur trans first and pick what kind stall u want to put in,that way safe for u and labor.
ULTIMATEORANGESS
09-08-2009, 07:13 PM
i have a vig. 3600 with 3.73s.
darrensls1
09-09-2009, 06:35 AM
My thoughts exactly.
FTICONVERTERS
09-09-2009, 12:58 PM
I say 3.73's and an FTI 9.5" billet 4000 stall.
Greg
nightmare23
09-09-2009, 09:13 PM
yup 4000-4400 and i would do 4.10s ;) ... killer at the track
manwithhate
09-14-2009, 01:21 PM
410 gears
Fbodyjunkie06
09-14-2009, 03:00 PM
Yank PT4000 and 3.73's FTW. Go with the stall first then get the gears. Also don't forget a tranny cooler when you install the stall converter they are a must!
COPO9560
09-14-2009, 07:38 PM
To pick the right gear you need to define a couple key items. First, how fast do you want to spin your engine, second, what is your target rpm at end of quarter without using OD, third, what is tire diameter. With an auto and loose converter, you should add 5% or so for slip too.
http://www.angelfire.com/fl/procrastination/rear.html
witry
09-15-2009, 10:52 AM
dont mean to hijack this thread
im about to go the same route a 3600 to 4k stall and 3.73 but my car is a DD would that be a good idea?
also for people with 3.73 that rpm's are you turning at 50,70,80mph thats my usual speed around here so i kinda want to know what the difference would be from my 3.23
stumprrp
09-15-2009, 11:02 AM
I have a 3600 yank and 3.73 gears.. After a week it felt like a stock car but my stall is way undersized for my cam which is a lot smaller then yours.. I vote for a PT4400 and the new 3.91 gears
