Gen 5 Camaro Drivetrain Tech - GEARS / ring and pinion
jay_lt4
09-08-2009, 01:11 PM
so whats the latest news, anyone heard anything at all??
gap4annie
09-08-2009, 02:17 PM
AFAIK there's no gears available yet but many are in the works.
Check http://www.camaro5.com/forums/forumdisplay.php?f=76 I'm sure someone will post a review or availability when they're out. I know Vengeance Racing is working on one
Ron@Vengeance
09-09-2009, 05:05 AM
We are working with a well known supplier to produce a 4:10 gear set for the 2010 Camaro. ETA is currently mid January. Ill spill more beans as more info becomes available.
Dark SS
09-10-2009, 09:09 PM
I think it needs every bit of that to get those huge tires spinning off the line. I eagerly await your info.
rayhawk
09-10-2009, 09:43 PM
Any other ratios planned?
You could also put a shorter tire on it and get the same result.
You would also be dropping some weight at the same time.
Robin L
09-11-2009, 11:29 AM
That helped us a bunch.
Gears would be better.
Robin
Robin
Are you being sarcastic or what?
The 2010 SS rear tire size is 275/40-20 which is 28.7" tall
A more "standard" size is 275/40-17 which is 25.7" tall
Now fitment and aesthetic issues aside.
That would be like going from a 3.42 to a 3.90 on a 4th gen Fbody.
I dont think that gearset exists, but the effect would be very similar.
Robin L
09-12-2009, 07:14 AM
Sarcastic??? I don't see how you got that.
Had Nitto's on the car that were slightly shorter than the stock tires.
We then installed the M/T ET Street Radials 303/40/17. They are as you say about 2" shorter which gave us more effective gear. As you point out about a theoretical 3.90.
It helped our NA ET with the shorter tires.
As I said in another post it is butt ugly with the shorter tires. Need to run at the track in the dark. There is a point where the mods are not worth the way they make the car look.
A 4.30 gear with the stock size tire would be ideal IMHO.
Robin
rayhawk
09-12-2009, 07:59 AM
Robin
LOL, you have to get them to turn the lights out on the track so nobody sees the roller skate look!
amwellls1
09-17-2009, 09:05 PM
Subscribing, I really want gears bad!
Grn4fbody
10-11-2009, 01:42 PM
Will these work for the 04-06 GTO as well?
jay_lt4
10-11-2009, 02:52 PM
nope, totally different rear diff assembly
