When i rev, My car vibrates
Old 09-09-2009, 01:19 PM
UnZFeat'd's Avatar
Default When i rev, My car vibrates
So when i rev the car in neutral, it seems normal and alright, but when i rev the car with the clutch in, it all starts to shake and vibrate badly. Anyone have this problem, or can tell me what it is? Thanks
Old 09-09-2009, 01:29 PM
Bad Blue WS6's Avatar
how bout in gear,, any vibs then?
I have the neutral vib issue, but i also vibrate in any gear, betweem 1800 to 2500 rpms (most noticable range),, my issue is my clutch..
Old 09-09-2009, 01:38 PM
UnZFeat'd's Avatar
actually, itll vibrate sometimes at load under superlow rpms, like when it stalls, but thats not really an issue, just a bit more vibrating than when you would usually stall it. Doesnt vibrate when it is in gear, though. However, i have noticed that sometimes i will grind a gear, even though i am positive i have the clutch pushed in, not speed shifting or anything, too. I just recently took everything out and checked my clutch and it has plenty of life on it, which suprised the hell out of me.
Old 09-09-2009, 10:10 PM
transam14's Avatar
check the mount
Old 09-09-2009, 10:40 PM
eseibel67's Avatar
Throwout bearing?
Old 09-09-2009, 10:52 PM
ls1kbush's Avatar
i would check the crank end play. Maybe somehow your thust bearings took a ****. Have someone push in on the clutch while you watch the crank pulley to see if it moves any.You should possibly be able to feel it in the clutch pedal if this is your problem. Good luck.
Old 09-21-2009, 02:50 PM
ozzyls12001's Avatar
i have similar issues in my car,i think its the clutch,mine vibrates in 2000-3000
in neutral with the Centerfoce 390510
my mechanic says that sometimes the new clutches doesnt come balanced
Old 09-21-2009, 03:12 PM
SPEC-01's Avatar
Though I certainly can't speak for every manufacture, when you buy our clutch and flywheel together at the same time they are balanced by us before shipping. If you bought a clutch alone and installed it on a stock flywheel then you should have had it balanced with the flywheel before install. We send info relative to this with our kits. Did you use the stock flywheel with an aftermarket clutch? Let me know and I will be happy to provide more info. Thanks!
Quick Reply: When i rev, My car vibrates
