Installing my clutch next week! *QUESTIONS*
How many miles on the car? If you haven't changed the tranny fluid and you've got 15,000+ miles on it, I'd do it. Also, go get a bottle of Valvoline DOT 3 & 4 brake fluid for the clutch hydraulics. It's literally "DOT 3 & 4".
http://www.valvoline.com/products/br...brake-fluid/28
Have fun with that Tick master.
You will need atleast a few quarts of whatever you are using for the tranny if you are draining it.. what I did is drain it and then put it back in the car dry. Then pop the drain plug and pour it through the shifter area (you have to remove the shifter to drop the tranny). Pour it until it starts to leak out the plug.. this is nice so you don't have the weight of the fluid when your trying to get the tranny back in place...
Do NOT put brake fluid in the transmission! That DOT 3/4 brake fluid is strictly for bleeding the clutch hydraulics (master cylinder / slave cylinder). For the transmission fluid, you can use whatever you prefer (Royal Purple Synchromax, Redline, Dex III, Penzoil Synchromesh, Mobil 1 Synthetic ATF, etc).
Sorry to ***** your tread. But its is necessary to drain the gear oil when pulling of the trans to do a clutch swap ??
I just changed the gear oil about 2 months ago...
Am i going to have one hell of a mess or can I leave it ?
thats the first thing you should do once ur under the car. also i didnt disconnect the hydrualic lines off the cylinder just unbloted it and took it off while lowering the tranny. So i didnt have to bleed the clutch. but if u dont have that drill mod do it.
