bogarts and hoosier qtp question
Ok i apologize up front but i need some help. i have a set of bogart 15x10 15x3.5 and im going with hoosier qtps. now what i cant figure out is what size tire to get this will be mostly track only use. i have a 98 camaro with strano springs. Can i fit a 28x11.5 or a 27x11.5 with minor fender work. Also front skinnie recommendations would be great. i don't know much about drag setups.
i have 3.90 gears m6 9" looking for the best size for my application. about 520hp n/a no 1/4 times yet.
27's will fit and shouldn't need any mods. Once you go larger, its pot luck. More than likely you'll be modifying something to make 28's fit. Adj. LCA's and PHR's are a must for the 28's.
Pick either mtt-1573 sportsman or an ET drag of some sort. Do NOT use a VW radial or other radial front tire for the wheels.
Good luck!
Good luck!
