Drag Racing Tech - Rear drag shocks
89camaro
09-09-2009, 09:38 PM
http://www.speedinc.com/cont.cfm?cid=C0000233 any one use these or heard anything about them?
SuperSlow02
09-09-2009, 10:12 PM
people like um for the price, and i think you can get them cheaper out of jegs directly
89camaro
09-09-2009, 10:15 PM
ill have to check it out im sure they would hook better then the stockers?
waterbug1999
09-09-2009, 10:16 PM
I have them on mine.. So far so good, not bad for the money.
89camaro
09-09-2009, 10:24 PM
I have them on mine.. So far so good, not bad for the money.what kinda tires are you running on the rear? do you still have the stock springs???
waterbug1999
09-09-2009, 10:32 PM
The track picture below is with my 26" ET street with a blown out shock so I upgraded to the competion eng. ones in your link..
On the street I am running a 315/35/17 hoosier drag radial with the car lowered 1".
89camaro
09-10-2009, 12:15 AM
were is the adjuster on the shock i looked at some pics and cant find were you adjust it at? is it easy to change the settings while its on the car?
waterbug1999
09-10-2009, 12:19 AM
Its kind of a pain.. If I remember correctly, you have to compress it and turn a little washer type deal on it... I just set it on the stiffest and left it.
89camaro
09-10-2009, 12:36 AM
dont you want it on one of the softer settings for drag racing?
waterbug1999
09-10-2009, 01:53 AM
I started on the stiffest and tried it out... It worked and had no issues hooking so i left it.
tomcowle
09-10-2009, 07:00 AM
no, your trying to control wheel movement
night ryder
09-10-2009, 07:21 AM
depends on the wheels you are using. i have my qa1s set at 3 and 5 because i have a low profile DR. since i do not have the side wall that a 28" tire has i need to soften the suspension to absorb some of the initial hit so it does not spin the tires.
a98ws6
09-10-2009, 08:49 AM
I've read there is a Summit shock that is just a rebadged Comp Engineering shock, just cheaper. Anybody know the part number?
ndfrsd6
09-10-2009, 09:05 AM
i have the comp drag shocks and go 1.40 60ft right off the truck ! there a great shock for the money !
BMR Sales2
09-10-2009, 09:50 AM
Awesome super budget shock. Have a few cars who have gone 1.35-1.40 60's with them. They are easy to adjust too all you to do is compress the shock and twist the body. There are 3 adjustments on them 90/10, 70/30, and 50/50. I mormally throw them in there on the 50/50 to start with and go from there.
tomcowle
09-10-2009, 11:22 AM
Summits are not rebadged CE's, but they do work great and for 26bux you can't go wrong
Pro Stock John
09-10-2009, 11:34 AM
I had those CE 3-position shocks in the white Camaro set at 50/50, 1.38's. I like QA1's since you have 12 settings since I've occasionally changed them from 6/6 to 7/7 for a better track but the CE's are okay.
fastGBcamaro
09-10-2009, 12:00 PM
I think a lot of people look past the stock shocks. Not that these aren't good, and having some adjustability is a plus, but if everyone says that for the money they are a good shock. I have gone 1.3's on the stock shocks and springs, and have seen several other members do the same. I think too many people just change out the shocks, when there are other suspension components that are more important IMO. Now if your trying to get a sub 10 second car to hook on a drag radial, then having an adjustable shock is a must.
airforcemanss
09-15-2009, 01:41 PM
what are some of the settings you guys are running on the street when you take her out on the wkends?
gyrene2003
09-15-2009, 02:10 PM
So is 50/50 the harder set up? With a stock spring and a low profile drag radial would I want to use the softer setting?
keith_AE2010
09-15-2009, 02:43 PM
Those work great. I have them.
Part number is g7700.
BETTER THAN YOU
09-16-2009, 07:59 AM
i have ran them for 3 yrs with 1.42 short times
Spd-Kilz
10-01-2009, 02:16 PM
Has anyone used these on the street?
How is it? Would you suggest it?
