Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Exedy twin plate slipping, how much to get rebuilt ?
Old 09-09-2009, 10:27 PM
allngn_c5's Avatar
Default Exedy twin plate slipping, how much to get rebuilt ?
Anyone know how much you can get an exedy twin plate rebuilt for ? Mine has between 25 and 28,000 miles on it if memory serves. Anyways tonight at Milan Dragway after about 9 passes she let go after the last run was complete. I pulled up to the time slip booth and when I tried to take off to get back in line for another run she revved and didn't accelerate in correlation to the rpms. I let her cool down and no improvement. I packed it in for the evening and missed my chance to get a good trap with the cooling air temps. At any rate I made it home safely. Just not the same being unable to give her a hard stomp on the accelerator. Felt like reduced power even though the motor was running strong. Oh well, 2 weeks in a row at the track, something had to give. At least I improved 4 tenths in the 1/4 by doing a proper burnout. (11.98 last week to 11.59 this week) Now if I can just get a better 60. (1.94x best so far) Much better then the previous 2.18x's.
Old 09-10-2009, 10:31 AM
pittman's Avatar
Originally Posted by wrb07sti
(1) the use of sodium silicate solution in the manner the agency has now adopted;
(2) destroying the oil filter sealing land and threaded fastener boss;
(3) drilling a hole in the engine block; and
(4) running the engine without oil.
Must have post to the wrong spot on you.
Old 09-10-2009, 11:10 AM
allngn_c5's Avatar
I'm thinking the same thing Pitt.
Old 09-10-2009, 06:08 PM
WKMCD's Avatar
Exactly!!!! Well said!
Old 09-10-2009, 07:38 PM
allngn_c5's Avatar
I nominate the above for "Random Comment of the Year" !!!!!!!!!!
Old 09-11-2009, 12:23 PM
SlowFRC's Avatar
I nominate him for "worst comment of the year" "worst poster in tech history" and "user that needs to be banned the most."
Old 09-11-2009, 01:15 PM
sultan(ZR-1)KSA's Avatar
dropp it and go for a spec 3+
Old 09-16-2009, 10:46 AM
allngn_c5's Avatar
Going with a better overall clutch. RPS street twin light. Adding Pfadt coilovers too.
Old 09-16-2009, 07:45 PM
regorih383's Avatar
Default the right clutch?
Have you tried LG, they should have a clutch for your set up.
Old 09-16-2009, 07:52 PM
allngn_c5's Avatar
Thanks bro, but I'm good.
Old 09-17-2009, 03:00 PM
david vericker's Avatar
I bet that it's a coded message from the KGB. We better get Interpol involved in this one. You know that we can never be too safe about this sort of thing.
Old 09-17-2009, 06:08 PM
pittman's Avatar
Originally Posted by david vericker
i bet that it's a coded message from the kgb. We better get interpol involved in this one. You know that we can never be too safe about this sort of thing.
lmao !!
Old 09-17-2009, 07:05 PM
gvzo6's Avatar
x2 i had that high $$$ pos exedy dd and went to a spec 3+ and love it
Old 09-18-2009, 03:56 PM
SLOC5LS6's Avatar
What were your traps with that 11.59 ET?
Old 09-18-2009, 04:35 PM
SLOC5LS6's Avatar
Why are you stuck on heavy twin disk clutches with only 540rwhp?? Go with a Spec 3+ and call it a day.
Old 09-18-2009, 07:54 PM
pittman's Avatar
I agree, the single does launch better IMO. I have a Twin again but the single slips great for launching 1.4 sixty foot times. Please no war of clutches...just my opnion !
Pitt
Old 09-18-2009, 09:13 PM
allngn_c5's Avatar
124.21 mph I actually think I let out a little early on that run too. Milans 1320 stripe is not as defined as the finish line as some tracks. All the adrenaline/nerves I may have let out just a bit. Reason I say this is because I have plenty of slips showing me pick up 33 mph or more in the second half of the track and on this one I only gained 28.5
Why would my better 60, better 1/8 cause me to lose on the big end. It should have added up everywhere. I think I let out a touch early. Who knows though. I talked to a buddy of mine, and we may be able to log some of my runs next time. Depends on his schedule.
For instance had I gained 33 mph that would've put me at 128.77 mph !!
Just glanced at my slips, I did 4 passes in just under 1 hr. Motor was a bit warm but felt strong as hell to me. How do N/A motors deal with heat soak ?
Old 09-18-2009, 09:20 PM
pittman's Avatar
Heat....not good. Will pull 4-5 degrees of timing and make you run like a lawn mower !! I lost 8 tenths and 5 mph in my 402 Silverado from the heat.
Old 09-18-2009, 09:45 PM
allngn_c5's Avatar
Thanks Pitt. I'll just have to chalk that up as another lesson learned due to inexperience. A little more cool down would've helped a lot I bet. Maybe I should hot wire the fans to bring the motor temp down quicker. Could be beneficial since I drive better hot lapping then sitting for 2 hrs between rounds. After 2 hrs my nerves are back. LOL. I know, Rookie.
Old 09-18-2009, 11:14 PM
Jimbo'sZO6's Avatar
**** Pitt, when I started hot-lapping at BB last weekend, I went from an 11.02 to a 12.41 when the car got too hot......these motors don't like too much heat!
Jimbo
Quick Reply: Exedy twin plate slipping, how much to get rebuilt ?
