Swap
Swap
This is a little project I did for a friend of mine..
Here is what we started with..
Started to tear into it..
LS7 Clutch Kit
Stock LS1 F-Body T56
Yes I used a Ratchet Strap to install it..
Installed with the factory Manual Cross Member and Poly Mount..
Here is the Interior..still have some finishing touches to do.
I cut the Pedal and put on a stock Cover, installed a Manual Steering Column Cover after I removed the Shifter, and did a little bit of wiring. The Shifter is a B&M Ripper with a little bit of an extention.
Not too bad for a few days of work, we still have a couple of bugs to work out, it drives very well.
Next is the 6.0l..
LS7 Clutch Kit
Next is the 6.0l..
