ls2 intake vs ls1 intake
Old 09-10-2009, 01:06 AM
silverM6TA's Avatar
Default ls2 intake vs ls1 intake
I have just bought an F.A.S.T. 90 off a friend with an ls2. it has the lower part of the intake(not sure what its called) that is black. he also threw in the fuel injectors he has which are stock and im not sure if they will work on my car or if they are any different at all. i was wondering if the intake and injectors would bolt right up to my ls1 or if i would have to make any type of adjustments. if it wont bolt up, what modification need to be made to make it fit from an ls2 motor to an ls1 motor? thanks in advance.
Old 09-10-2009, 05:45 AM
alottaboost's Avatar
injectors and, i believe, the fuel rail mount differently between the two.
Old 09-10-2009, 06:53 AM
SweetS10V8's Avatar
The 90mm will bolt on, use your rail and injectors. The LS2 injectors are 34lb/hr and are a different length and require a tune to make them work correctly.
Keep the injectors for later upgrades or sell them.
Old 09-10-2009, 07:19 AM
I knew I was close lol.
Old 09-10-2009, 11:27 AM
silverM6TA's Avatar
k cool. thanks guys. ill bolt up the fast and sell the injectors and fuel rail i guess.
Old 09-10-2009, 11:55 AM
blacksheep's Avatar
Don't forget to change the valley cover bolts or your will crack the bottom of the intake.
Old 09-10-2009, 05:28 PM
silverM6TA's Avatar
valley cover bolts???
Old 09-10-2009, 05:31 PM
NemeSS's Avatar
FAST intake come with pan head, round head, lo profile type screws. to provide clearance for intake belly, if not used, the stock bolts will and can crack the intake.
Old 09-10-2009, 06:40 PM
silverM6TA's Avatar
i didnt get any of these screws. is there a website or something i can order them off of?
Old 09-10-2009, 07:53 PM
silverM6TA's Avatar
is this what im needing to install my FAST. or is there something else? im just confused bc he had the stock bolts on his GTO.
http://www.ws6project.com/user_stor/...roducts_id=820
