Tsunami cam?
Old 09-10-2009, 04:57 AM
F-Body Lover's Avatar
Default Tsunami cam?
what do you think of this cam? my friend got M6 2001 Z28 that has LS6 stage 2 Patriot heads,full bolt ons and I mean everything even the oil pump is LS6 ported every bolt on you can think of,stock LS6 intake,Torquer 2 cam and stock 3.42 gears the car had 427rwhp/400rwtf and the clutch was burned so now it has Monster stage 3 package and we are thinking of changing the cam to Tsunami cam for those who dont know the numbers here they are 235/240, .654"/.609", 111 LSA we are concerned about valve to piston clearance the short block is stock nothing changed so will we have valve to piston clearance with that much lift? the heads were never milled and I think the springs can handle .650" lift can they handle the .654" ?
Old 09-10-2009, 05:30 AM
alottaboost's Avatar
I would go with their .675 springs...
http://www.texas-speed.com/shop/item...=1013&catid=48
Old 09-10-2009, 08:51 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
I wouldn't make that change with those heads. You don't know that you'll have proper valve drop to maintain piston to valve clearance. You could check it prior to ordering a camshaft, but I'm just not sure you'll have clearance. Do you know the valve size? I can help you take some measurements of the head to get a idea how much valve drop they have left, but it's ALWAYS best to check it just to be safe!
We might be better off thinking about a little bit smaller camshaft if we're not sure.
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 09-10-2009, 03:49 PM
the valves are 2.02/1.60 if this cam will have valve to piston clearance issue then we will order a custom grind cam that has high lift with almost same duration
Old 09-10-2009, 11:38 PM
TransAmcoupe98's Avatar
That cam is made for bigger cube motors, your best bet is to go a little smaller.
Old 09-11-2009, 01:27 AM
suggest the best cam for the combo that car has and it can hit 435+rwhp
Old 09-11-2009, 01:42 AM
how about Torquer V.3 ? it has high lift and thats good for us 231/234 .643"/.598" 111 LSA
Old 09-11-2009, 12:48 PM
Fbodyjunkie06's Avatar
I say you alread have a good cam in the Torquer V2 the Tsunami specs on lift and lsa aren't much different with only a little bump in duration. I'd say that to meet any bigger goals with a bigger cam you'll need to flycut and get a custom cam ground and not choose an off the shelf grind.
Old 09-11-2009, 11:58 PM
BTW, if you have springs rated to .650 lift and your cam has .654 lift, they will break in the matter of weeks.
Quick Reply: Tsunami cam?
