Need some metal valve stems
Old 09-10-2009, 11:07 AM
omcar's Avatar
Default Need some metal valve stems
Which metal valve stem do you recommend for my stock 16" factory wheels?
Thanks
Old 09-10-2009, 11:10 AM
camaross00black's Avatar
Default metal valve stems
i would just go to any parts house r ntb or discount tire and they should be able to hook you up
Old 09-10-2009, 01:06 PM
hitmanws6's Avatar
out of curiosity why do you need metal? rubber works just fine
Old 09-10-2009, 03:10 PM
k5383's Avatar
There is not really a reason to use metal stems, save for high load range tires which underload will blow out.
But, I also prefer the metal stems. They don't dryrot, and like already said any parts house or local tire shop *should* have them in stock.
Old 09-10-2009, 03:25 PM
TA1364's Avatar
If you run 11s metal valve stems are required.
