T-56, TKO-600 or what?
I have T-56 from F-body for my racecar project, how much torque / Hp it can take and what are it´s weak points, plan is 450-500whp NA LS1.
I´ve also have been thinking of buying TKO-600 and to save this T-56 for my other street car project. Does T-56 Bellhousing(?) or clutchhousing(?) (which one is it, little language barrier) fit directly to TKO-600 gearbox?
A T-56 will hold 500WHP no problem. weak points in a stock T-56 would be 3-4 shift fork and Synchronizers
The weak points in the stock T56 are:
1) Plastic fork pads
2) Stamped steel syncro keys
Upgraded billet keys installed
Compared the 2
3) Aluminum 3-4 shift fork
But you can upgrade the above listed items and be good for about 600 FT LBS.
Compared the 2
Contact any of the transmission vendors on here and tell them you wanna do the basic upgrades to your T56. It should take a couple hundred bucks and it'll be a damn stout trans for the $$$....better yet, you'll have a steeper overdrive compared to the TKO600.
I had a T56 in my TA, I have a T56 in my GTO, and I have a TKO600 in my Cobra. I'd have the TKO proshifted for the race car and I'd do the basic upgrades to the T56 for the street car.
-Will
-Will
They make brass fork pads i currently have 1/2/3/4 and we are currently in the process of installing the new 5/6 brass pads today. ( was having problems with getting into 5'th gear because one of the plastic pads broke on the 5'th/6'th fork )
I have full billet keys
All brass pads
All steel forks besides 3/4 <--- kinda gay they dont make a steel fork for 3/4
Other then that i have no problems at all and im good up to 600 ish
All brass pads
Uhhhh, yes they do.
http://www.morrismotorsports.net/t56_parts_for_sale
On a side note to OP....the T56 will handle A LOT of abuse, when properly setup. As pointed out already, weak links (and easily fixed) are teh stock nylon fork pads, stamped shift keys, and the aluminum 3/4 shift fork. One thing that was not mentioned is the upgrade to carbon fiber blocking rings (stock they are paper lined)
When you say 450-500rwhp N/A ls1 do you mean LS1 based build or a stock cubed ls1? The T-56's don't like to shift after 7K+ rpms and you're shifts should be right around that area when nearing the 500rwhp mark with a N/A 346.
