no brake light in cluster
Old 09-10-2009, 09:05 PM
hawaiic5's Avatar
Default no brake light in cluster
the brake light on the gauge cluster do not turn when hand brake is engage. does anyone know where to check to fix this problem? any help is much appreciated. i search but nothing seems to be related with this problem.
Old 09-10-2009, 09:11 PM
shtnfrds's Avatar
does it light up when it does the light check when the key is initially turned on?
Old 09-10-2009, 09:12 PM
00ssmg's Avatar
you may want to search under daytime running lights. alot of people bypass their drl module which effects the brake light on the dash. there are a couple posts. just something to look into. hope that helps
Old 09-10-2009, 09:55 PM
NSSANE02's Avatar
Check the sensor on the handle, if it's disconnected the light won't come on.
Old 09-11-2009, 07:30 AM
hawaiic5's Avatar
i forgot to mention that the brake lights dont come on even on start up. ill double check the sensor at the handle again.
