SES question
Old 11-28-2003, 06:25 PM
cameroz282k's Avatar
Default SES question
ok guys i just did a heads and cam now im getting a ses light for o2 sensors i have replaced them with bosh sensors and sitll get the same code any info on this will help thanx
Old 11-28-2003, 07:29 PM
2000silverbullet's Avatar
What code are you getting?
Old 11-29-2003, 09:47 AM
its coming up as bank 1 sensor 1 so that is the driver side pre cat and rear are on sims
Old 11-29-2003, 08:06 PM
What A/F mixture are you running?
Try and delete those codes by removing pcm ign and pcm bat fuses & see if code comes back.
I'd make sure that the A/F mixture is good.
Good luck!
Old 11-30-2003, 02:53 PM
LT1TECH2003's Avatar
dont use bosch 02's, get ac delco. i have had alot of problems using aftermarket 02 on numerous cars
