How to check gear ratio?
is there any way possible to check what gears i have in my car with out taking off the rear cover and counting teeth i have the TA HD cover and its a pain to take off and torque back up but i just want to know by maybe looking at the drive shaft and tire movement and going from there
thanks matt
thanks matt
1 Post
jack the rear end up off the ground, put a tape mark on the 12 oclock position of both wheels and then us a magic marker on the drive shaft. have a friend watch the tires turn 1 full revolution when you turn the drive shaft. as you get around 3 times around with the shaft you should be closing on 1 full tire revolution. when the friend says you've gone 1 time around, look at where your mark on the drive shaft is. The 3.23 will be easy to see the mark in the direction you were turning halfway up. 3.42 will be hard to see since it'll nearly be at the top and so forth...
Jack the back of the car up. You want one exact turn of the wheel. So roll it around till there is something to reference. For instance, I used the valve stem at a perfect 12 o'clock position. While under the car, mark the driveshaft facing directly 6 o'clock with a sharpie. Have someone spin your wheel exactly one turn. Count the times the driveshaft turns. So 3 full turns plus another 1/4 of the DS means you have 3.23s. Slightly more then four full turns would be 4.10s. And so forth.
