How do I get this last manifold bolt?
Old 09-11-2009, 07:19 PM
XtremeDime's Avatar
Default How do I get this last manifold bolt?
Im currently taking my stock exhaust manifolds off for a turbo setup, Ive gotten all of the bolts off except for the one in the back of the passenger side. I can barely get it on there and when I do I can hardly get it a quarter turn before it slips off. HELP!
Old 09-11-2009, 07:24 PM
Restricted User
1BAD_LS1's Avatar
try from the bottom
Old 09-11-2009, 07:28 PM
XtremeDime's Avatar
The exhaust is in the way, and I cant seem to get the bolts loosened there either.
Old 09-11-2009, 07:36 PM
zamora7's Avatar
I did it with a 3 inch extension, but remove your coil brackets out of the way. mine were proly easier because my heatercore lines are rerouted. But I had to do it like 1/4 turn by 1/4 turn, PITA
Marinez28's Avatar
Hve you not taken off the y pipe and cats? If not, drop all that and go from the bottom. A 10mm ratchet wrench and a lot of patience is what it takes.
Old 09-11-2009, 07:37 PM
Parasoth's Avatar
if you have not already, remove the coil packs.
Get a 1/4th ratchet, use a converter thingy, so it makes it the size of a standard ratchet. This prevents destroying 2-3 of the smaller sockets.. like I did. Cracked 3 of them right in half.
Get a short socket (I can't remember the size and I just did this. Go figure.)
Lay on top of the engine bay.
Tough it out.
The smaller rachet gives extra room to get more clicks in. It still takes a buttload while, but it will get done.
Old 09-11-2009, 07:45 PM
intense3123's Avatar
gear wrench
Old 09-11-2009, 10:48 PM
kkslds's Avatar
gear wrench
x2 ratcheting wrenches are life savers. Still takes awhile but alot easier than a standard ratchet imo
Old 09-11-2009, 10:54 PM
twitchtwice's Avatar
I had the cats still on. From under the car it is very easy to get to
