Gears & Axles - Axle spline question
99-LS1-SS
11-28-2003, 10:01 PM
Can someone explain the differences in the number of axle splines? I understand that 33 is more than 34. I want to know which is stronger and why.
SMOKIN01TA
11-28-2003, 11:07 PM
i believe you can get up to 35 but i have the 33 the bigger the number the stronger, i guess the more splines the greater pressure they will take before they will twist. 33 is more that enough for a 8 sec. car
99-LS1-SS
11-29-2003, 07:35 AM
Why would they offer different spline numbers if one isn't as strong as another? Is there a drawback to the stronger spline?
SMOKIN01TA
11-29-2003, 02:13 PM
same reason they offer a variety in everything else, you pay more for the higher quality. also the more splines i was told the noisier the rear end will be. and if you dont want a 8 sec car than you would be fine with 30 or 31 spline axles. they are cheaper and quieter and dont come with a free replacement waranty if you break them but if you not going to have the power to break them and you want less noise go with them.
99-LS1-SS
11-29-2003, 08:53 PM
Thanks
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
