Got the ebay turbo kit on
Old 09-12-2009, 09:23 PM
XtremeDime's Avatar
Default Got the ebay turbo kit on
So far the headers line up perfectly! So far Ive just done the headers but I will let you know how the rest goes!
Old 09-12-2009, 09:24 PM
TurboZ28408's Avatar
hhahah wait till you have to deal with all the vbands lining up
so far you put the headers on and thats it ? no cross over pipes nothing ?
Old 09-12-2009, 09:38 PM
Reject's Avatar
better make sure to leave everything loose before cranking down on the bolts, nothing will line up if you dont
Old 09-12-2009, 09:54 PM
XtremeDime's Avatar
I put it all together off the car before, had no issues there. I have a plan for the v clamps already.
Old 09-12-2009, 10:08 PM
98Camarod's Avatar
This isn't the PTK replica kit is it?
Old 09-12-2009, 10:09 PM
yea its the same thing
Old 09-12-2009, 10:13 PM
98Camarod's Avatar
In that case, I didn't have a problem with my v band clamps
Old 09-13-2009, 02:53 AM
KILLER-LS1's Avatar
yep, mine is directly from godspeed and i had to notch a v-band, weld another 02 bung since the passenger side didnt have enough room for the sensor, and since im running a t76, i had to make a custom downpipe. i just finished mine, it will be at the dyno this week. im writing the instruction manual for godspeed, so you will all get to see that soon!
Old 09-13-2009, 02:09 PM
its just a pain in the *** for them to line up if he just bolted the headers on without leaving everything loose and tightening in sequence
Old 09-14-2009, 12:29 AM
scottie dont's Avatar
any pics of how its mounting yet? im kind of curious about these kits.
Old 09-14-2009, 12:38 AM
XtremeDime's Avatar
Got everything pretty much bolted up, havent had too many issues so far. Im a little confused on the belt routing though. I see everyone that has these PTK knockoffs are exactly the same, can someone show me pics of their belt routing or draw me a diagram?
Old 09-14-2009, 07:56 AM
98Camarod's Avatar
Starting from underneath the waterpump it goes over the powersteering, around the idler, around the crank, around the alternator, and back under the waterpump
Old 09-14-2009, 11:31 AM
Dean95z28's Avatar
Fair warning go ahead and build a turbo brace! I hit a pot hole the othe day and cracked the turbo flange section of pipe at the v band flange. Got it all apart getting it ready to weld back up!!!!
Old 09-14-2009, 02:04 PM
98Camarod's Avatar
You hit a pole. How does putting a turbo brace help?
Old 09-14-2009, 02:26 PM
Dean95z28's Avatar
A pot hole in the road. Jared the car really hard. All the weight of the turbo hanging out there on that pipe and it cracked.
Old 09-14-2009, 07:16 PM
98Camarod's Avatar
L O ******* L. I was drunk and I read that you hit a POLE not a POT HOLE
Old 09-14-2009, 08:30 PM
XtremeDime's Avatar
LOL I was sober and read pole also, I had the same reaction you did!
Old 09-14-2009, 08:40 PM
XtremeDime's Avatar
XtremeDime's Avatar
Old 09-14-2009, 10:49 PM
98Camarod's Avatar
I'm glad I wasn't the only one
Quick Reply: Got the ebay turbo kit on
