low pedal engagement after break in
I installed my spec stage 1 clutch about 1000 miles ago. I gave it a proper break in but my pedal is still engaging about 1-2 inches off the floor and it doesn't want to power shift at anything above 4500rpms but it completely disengages. I installed the supplied slave shim, the hydros were bled properly. the only thing I can attribute this problem to is the machining of my flywheel. It is the first machining and the shop took .040" off! So I bought 1 of 2 choices of flywheel shims they had for it: .025" or .050" so I took the 25 thousants.
I guess my question is could this .015" of unaccounted for metal be the root cause of my low pedal engagement or should I look elsewhere.
adjustable masters do not fix the real problems.
I would pull the trans and measure the throwout to PP distance.
https://ls1tech.com/forums/manual-tr...need-shim.html
More shim will raise the pedal
