What do you have your window switch set too??
Old 09-13-2009, 10:53 AM
99WS7's Avatar
Default What do you have your window switch set too??
Are a lot of you guys doing the typical 3k to 6k deal or are you leting the spray stay on until you shift...also what rpm are you shifting at?
I have mine set at 3k and going off at 6k and I shift at 6400 but Im thinking about letting the spray stay on longer so I can get a better ET.
Any thoughts?
Old 09-13-2009, 11:57 AM
01SOMZ28's Avatar
mine is on at 3200 off at 6000, i launch at 3000 shift at 6200
Old 09-14-2009, 06:56 AM
blue99fbody's Avatar
Mine is on at 3000 off at 6500 and revlimiter is at 6700
Old 09-14-2009, 09:08 AM
jmm98LS1's Avatar
On at 4000, off at 7000. Rev limit at 7200.
Old 09-19-2009, 02:23 PM
imma_stocker's Avatar
How quickly will the nitrous cut-off respond compared to the ECU?
If the limiter is set to 7200 but shift at 6800, and set the window to 7000, what will happen during a hard shift? I'm trying to imagine this but it seems a fair sized shot would create a lean spike at shutdown and another getting back on the throttle.
Old 09-19-2009, 03:01 PM
mitch cobb racing's Avatar
on the street... 3000 and 5800
at the track with better fuel... 1500 and 6200
Old 09-19-2009, 07:12 PM
Z-RATED94's Avatar
I spray through the shifts. 3600-6500rpm. I was told the that it really never stops spraying if you set it to shut off right before the shifts. Reason being, once the trans starts to shift and the revs start coming down the nitrous is back on anyways.
No bashing please, just stating what was explained to me.
Old 09-19-2009, 10:06 PM
Gary Z's Avatar
Same here.
Old 09-20-2009, 10:56 AM
tals7's Avatar
Smile
0n at 2400 off at 7100.7600 rev limit.
