wheel stud question
Race your car!
No you don't. Just unbolt the backing plate, and remove the sensor out of the plate. Then you can slide the stuf thru the hole, tap the head past the reluctor ring and then draw the stuf into the axle with an extra lug nut and a bunch of washers. Use grease too, that will help stop the washers/lugnut from binding.
I have done it with a couple cars with no problems.
