View Poll Results: What should I do?
Get a 22mm rear bar & get a matching front bar later on.
0
0%
Voters: 3. You may not vote on this poll
Wich rear sway bar to get?
My car is awating a big install:
Ford 9" w/ locker
drive shaft
d.s. loop
T. arm
Tranny bracket w/ T.arm relocation
I need to get a rear sway bar also. This is a street/strip car. I want to launch straight at the track. I dont care much for handling, but I also dont want to fishtail the car on the street. I dont know what to do...
Ford 9" w/ locker
drive shaft
d.s. loop
T. arm
Hello
I noticed that you are looking into a sway bar set up! And I just wanted to suggest to you that UMI Performance as a 22mm solid to help with you handling and control body roll. Below is a link to show you what we have to offer.
http://www.umiperformance.com/catalo...b43rvn1fe7q394
If you have any other questions feel free to ask and I will be more than glad to help.
Thanks
Brad
Thanks
Brad
LS1TECH Sponsor
I have a 22mm rear bar that is adjustable... In short it's like 3 bars in one (it's 3 position adjustable). On the softer setting it's not going to cause you brutal oversteer, but you can stiffen it way up for launching so the car leaves straight. But you aren't stuck with a massive rear bar all the time like you would be a drag bar.
For that matter our endlinks are also adjustable, so you can preload the bar if you want too. This is not our hollow rear bar but a stand-alone, fully bolt on, 3-way adjustable rear bar.
http://www.stranoparts.com/partdetai...=126&ModelID=7
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1Tech Premium Sponsor
Ford 9" w/ locker
drive shaft
d.s. loop
T. arm
Ford 9" w/ locker
drive shaft
d.s. loop
T. arm
Hello, we have a couple options for you. We have our rear 22mm bar that is a huge upgrade from the factory one or we have our xtreme rear anti roll bar that has been into the low 7 second 1/4 mile zone and is also capable of being used on the street. The xtreme bar is intended for racing but we do have customers that use this bar on their street cars. It makes the rear stiff but you can undo one link off of it and it makes it a little more tolerable. For the ultimate performance it can't be beat. If you have any questions about any of BMR'S products please give me a call.
