Need Expert advice about 175 shot
I am planning on dynoing a 175 NX shot next month on the dyno. IM part of NorCal-LS1 and nobody has done that on a stock block, i was wondering if anyone knows the limits to a stock block as far as horsepower, and nitrous and if its recomended. I have a spare motor at home and ill change it out in a weekend if i pop this one so im not worried about it. I have the 28lb injectors and a fuel pump. Stock ported heads, LT's, cam, LS6 intake. This motor is a 2002 if that means anything. Were thinking i might hit 580rwhp? But im not going to throw that number out till i know. What are your thoughts on this,?
u on crack... i did 200 on a stock block sucka better get a better fuel pump ( 255lph walbro ). block will handle it for a while provided u dont lean it out detonate... race gas only. and TR6s... loose 2-4 degrees of timing.
Originally Posted by taqwache
hey silver, you sprayed 200 on a single NX nozzle?
i dunnp if it was 200 or bigger
it was single nozzle (NX,shark nozzle), no jet in the nos side and 54 or 55 jet for the fuel
mods was intak fuel pump, 42 inj,cam
