Inside Diameter of 1 3/4 headers?
Old 09-14-2009, 01:58 PM
witry's Avatar
Default Inside Diameter of 1 3/4 headers?
im asking this because im in the middle of porting my heads and i dont have the headers yet they should be here sometime at the end of the week but i need the heads done by wednesday to get them to the machine shop so i was just wondering if the inside diameter of the header was actually 1 3/4 or is it a little bigger i used a mic and the gasket is 1.816 inches so i just want to make sure the header is aither a little bigger or the same size
thanks
Old 09-15-2009, 08:49 AM
witry's Avatar
i know its a stupid question but i need to know
Old 09-15-2009, 09:13 AM
SSCamaro2000's Avatar
The gasket is probably a bit bigger than the actual diameter of the primaries. If the inside diameter is not 1 3/4" then its going to be damn close to that. Again im not sure on either but I do believe I am right here, hope this helps.
Old 09-15-2009, 09:38 AM
TooLateVTEC's Avatar
Inside diameter should be 1-3/4". Thats where they come up the that measurment.
You want the gasket a little bigger than the primary so the exhaust doesnt burn the gasket away from covering the exhaust port...its perfectly normal.
Old 09-15-2009, 09:47 AM
Quick Time's Avatar
All exhaust tubing is measured on the outside diameter. So the inside diameter of the header also depends on how thick the material each header manufacturer uses. Most use .049 or .065 thick steel. So it would be 1.652" or 1.62". Hope this helps.
Old 09-15-2009, 09:56 AM
CARTEK Racing
WS6TransAm01's Avatar
Really? Good to know... I honestly thought that tubing was measured on Insite Diameter... hu. Learn something every day...
Old 09-15-2009, 10:04 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Agreed, every header I've measured (Kooks, Pacesetter, ARH, etc) are all measured OD.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 09-15-2009, 10:55 AM
witry's Avatar
same here didnt know that aither... so i should just wait and see what mine are, i ordered the pacesetter LT
