Stereo & Electronics - where did you guys run your amp power wire
Chrisd000111
09-14-2009, 03:48 PM
i have a 4 ga. wiring kit, i want to keep the wire running down the pass side but i cant find anywhere to run the wire through the firewall, the rest is easy but i cant find a spot to run through without drilling.
thanks chris
Engine_HP
09-14-2009, 03:52 PM
no drilling, pass it through the pcm firewall passenger side kickpanel, its eisier to see it when the hood is open behined the pcm.
Chrisd000111
09-14-2009, 03:57 PM
i looked back there do i have to take the pcm loose to get to it
Engine_HP
09-14-2009, 04:09 PM
no need, just loose the bolts and push it to the side.
Chrisd000111
09-14-2009, 04:14 PM
ok thanks ill try that
94'BLKBRD
09-14-2009, 04:50 PM
You don't need to loosen the PCM bolts.
brandotron
09-14-2009, 04:52 PM
Makes it a LOT easier if you do.
