from ls1 to lt1 brakes
ok so i bought a moser 9 inch with lt1 backing plates. i'm trying to weigh my options as i do not want to devalue my 01 trans am rear.
will ls1 calipers/pads/rotors work with an lt1 backing plate?
if i must use lt1 calipers, will the pads from my ls1 calipers fit in the lt1 calipers?
and finally are the rotors interchangable for either set up(with ls1 or lt1 calipers on lt1 backing plates)
thanks in advance fellas
I swapped over my lt1 style to ls1 style rear, they are 100% differnt and non combine-able but u can get the 2 parking brake lines the backing plate and u already have the rotors and calipers and ur good to do a direct swap. It cost me 50 bucks for the complete ls1 rear brakes and lines might as well buy some SS lines while ur in there
aliright i decided i need to go ahead and put ls1 brakes on this basterd. so i just took my axles out of my 9". gonna get the bearings pressed off and some new ones for it along with have the reluctor rings pressed on. i need ls1 backing plates and is there anything esle? i'm going to take the calipers and rotors off my trans am and put them on the nine inch. anything im missing to have full ls1 brakes on the rear??
