Taking bets on what my set up willl run!
Old 09-14-2009, 09:02 PM
35thsscamaro02's Avatar
Default Taking bets on what my set up willl run!
Going to the track tomorrow to see what my new set up will run. Heres what I have.
2002 M6 Camaro SS
Stock bottom end ls1
228/228 si4 comp cam 113 LSA
Patriot performance ls6 heads
under drive pulley/ ported throttle body /lid bellow 160stat
spec 3+ clutch new master/slave did drill mod
STOCK 10 BOLT 342 gear sub-frame connectors and lower control arms
Walbro 255 pump hotwire kit and 42# injectors
Dry Nitrous shot single nozzle with N.O.S .069 Jet i think it is around 160hp
No major weight reductions normal stuff spare tire/jack
have 275/40/17 M/T drag radials
I will be slipping clutch on launch spraying between 3000-6300.
Who every guesses closest to what I actually run wins. And yes breaking my rear-end is a acceptable guess
Old 09-14-2009, 09:23 PM
camscam02's Avatar
14's is my guess
Old 09-14-2009, 09:39 PM
vodas00ss's Avatar
Red face
if you drive that thing to a 14 you need to sell it and get either a smart car or a walker with tennis ***** on the feet i say 12.80's with street tires if you can drive a little.
Old 09-14-2009, 09:40 PM
I ran 12.8 with stock clutch street tires and just bolt ons/ exhaust
Old 09-14-2009, 09:43 PM
ttranssam's Avatar
youll run a best of 11.2 spinning.....then your going to pop a cherry....and not some bitches...lol
Old 09-14-2009, 09:45 PM
ttranssam's Avatar
there was a guy on passtime with a four eye shitstang with 350 rwhp but a 200 shot spraying off the line ran a 9.9....friggen nuts...
Old 09-14-2009, 09:48 PM
no ****? damn what did it weigh 2000 lbs lol
Old 09-14-2009, 10:06 PM
ttranssam's Avatar
prolly next to nothing...but it looked to have most of the interior???
btw....your state sucks...lol
Old 09-14-2009, 10:08 PM
Thats funny because if im not mistaken we kicked your *** the other day at the Dome! GO MIZZOU
Old 09-14-2009, 10:35 PM
ttranssam's Avatar
...lol, out side that, i went to ozark and had the worst time of my life...
Old 09-14-2009, 10:53 PM
vette0009's Avatar
18 Flat, Good Luck
Bon
Old 09-15-2009, 02:57 AM
jmill96Z's Avatar
11.79 @ 118
Old 09-15-2009, 06:12 AM
slammin86's Avatar
11.28 @ 126
Old 09-15-2009, 07:38 AM
rmata's Avatar
12.1 at 120mph. You bogged out of the hole pretty bad, lol
Old 09-15-2009, 08:42 AM
Grifter's Avatar
DNF.
10 bolt......BOOM!
Old 09-15-2009, 12:47 PM
TARZAN's Avatar
Its gonna roll about 57 feet after you break the 10 bolt
-Will
Old 09-15-2009, 11:29 PM
Results are in First pass did horrible burnout ran a 2.4 60 foot not spraying in first ran 12.5 at 123 Second pass of the night with a 3000 rpm clutch slip twisted drive shaft in half moving about a foot! Also no drive shaft loop .yet no body damage! what a night!
Old 09-15-2009, 11:51 PM
rmata's Avatar
Looks like I was the closest. You can paypal me $5 for winning, lol
Old 09-15-2009, 11:52 PM
jmill96Z's Avatar
Well that sucks. Now you know why they make you run a loop. I should be the last one to preach on safety stuff though. That 123 should give you hope though. Could be touching 10's if you get it to hook.
Old 09-16-2009, 06:32 AM
yeah im still pretty happy about it. I think if i spray in first next time my trapspeed could be a little bit higher maybe 125+ maybe. so im thinking if i save up for rear end and drive shaft i could be in the 10's
